Reverse Engineering Motor Signal Board Day 6 - Weird ground shield, new ideas
A project log for Reviving and Reverse Engineering an Old Robot Arm
A full reverse engineering and rebuild of a Mitsubishi Movemaster robotic arm
taylor-schweizerTaylor Schweizer 06/05/2020 at 03:050 Comments
This is getting extremely complicated extremely fast. A few things I've noticed (is anyone even reading these logs?):
Here's my idea - I really, really want to make an identical board but with modern components. For instance, instead of using the 20 pin DIP packages for the SN74LS240N, I want to use the 20 pin SOIC package. Replace all transistors with a sot-23 package, resistors with 0805 SMD, etc. Basically I want a board with the exact same number of items on the BOM, but with all SMD parts. Just to see how small I can make the board. No idea if I'll actually do this or not, really seems like I'm writing this just for myself.
There will be a few pictures today, the usual zoomed out view as well as some specifics on both the layout and the schematic.
Here is the weird ground trace. Quick color convention - blue traces are on the bottom, yellow traces are on top, the black traces are ground traces. They surround the clock trace.
Here is most of the schematic for the encoder for joint 1. This is just one joint. There are 4 more. But just like the input conditioning, it seems to be duplicated.
