Amplifer 60->100W
60W -> 100W Texas Power Amplifier for home SUB boxes
Don’t execute your neighbor, he can do more than you think.
At that time, even the Watt calculation was real, it didn’t mean like unfortunately on today’s amps!
The heat sink below 2 BD should have mica and screw head insulator.
Next to the silicone grease!
If today’s BD transistors are metal-free insulated, then only silicone grease should be on the ribs and transistors published. It depends on what they give.
The 0.22 Ω resistor pair can be made of thin lacquered copper wire or ask for higher power pieces!
Because the full power goes into these two.
The power can be significantly increased with the secondary output of the transformer!
W = V x A
Wiring diagram, parts list.
Volume input Potenciometers 2x100KΩ
  • 1 × 1x 250W toroid transzformátor 1x220V 2x37V
  • 1 × Greatz
  • 1 × 2x 4700-->10000 μF electrolit capacitor
  • 1 × UA7812 Stabilizator
  • 1 × Power Suply Components
View all 6 components
  • Useful suggestion
    Kerekes Zsombor05/14/2020 at 15:01 0 comments
    From the input through the volume cutter to the desired tone control from there to the output. Use a shielded wire between each. Exception is thick power and speaker wires.
View project log
Kerekes Zsombor wrote 05/14/2020 at 14:58 point
