X-Ray Crystallography
Using a narrow beam of X-Rays to produce an image/data that reflects the atomic and molecular structure of atoms in a crystal.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The aim of this project is to use a narrow beam of X-Rays to produce an image/data that reflects the atomic and molecular structure of atoms in a crystal. The method used is called X-Ray crystallography where a narrow beam of X-rays is fired at a crystal, although most will pass straight through some of the x-rays are diffract by the lattice of atoms arranged in a crystal which sum and subtract to create an interference patterns at an angle to the main beam. The Xray Tube is currently working and I am currently developing a si pin detector and experimenting with raster scanning method. Imaging and data not intended to be scientifically accurate. http://www.hardhack.org.au/crystallography
