Setup
A project log for Ear Saver Router CNCing
Protect your ears from face mask ear loop burn!
brucejdiibrucejdii 05/19/2020 at 00:020 Comments
I used an off-cut as a strait edge to align the "Even" Bottom sides of the materials.
I used shear to cut the material to size, tin snips would have worked as well.
Use a Sanding Block on the surface of the Spoilboard after each sheet.
The Scotch tape DID work!  But only on a clean spoilboard surface.
