90X90mm PCB
A project log for M10CUBE
M10CUBE (M10 in short) is a modular controller box with cube dimensions 10x10x10cm. Raspberry bus will be used for the first incarnation.
vasilis-vorriasVASILIS VORRIAS 01/21/2021 at 12:371 Comment
It looks that 91X91 PCB dimension is a bit strange. 90X90 seems more appropriate and does not reduce really the real estate of the board. PCB Calculations are easier that way.
A small reposition on the 40 pin Raspberry connector made so the center of the connector to be aligned with the center of the mounting holes. The same way things done on the Raspberry Pi .
It is very crucial on this redesign to fix PCB outlet, mounting holes and Raspberry PI 40 long pin connector that connects various boards together.
PCB is still open for suggestions.
We are talking now with a very old and established company in electronic design.
Hopping that discussion will produce an even better M10CUBE design for the community.
A PDF and a step file will help you to see the actual proposition
We are open to discussions and criticism.
1 - STEP file
2 - PDF file
https://drive.google.com/file/d/1yRPqU383x6fnzrjMYXi4AUmQ6xDtixmj/view?usp=sharing
https://drive.google.com/file/d/1-Jwz05DQahxnaDgEAwje6dV2fpPQ8MXz/view?usp=sharing
axdes6bf wrote 04/23/2021 at 00:59 point
A project log for students is now publish. This log is for those who need to take it and wants some good ninjaessays data which help them to keep the material where we need to solve the whole things which we have to manage when we are going to publish this.
