Daughter boards arrived
A project log for Control Media player with Pro Micro
Control the Mpxplay Media player with just a Pro Micro, Rotary Encoder and a little Nokia 5110 display... (any OS including DOS)
michael-otooleMichael O'Toole 05/28/2020 at 19:090 Comments
The little daughter boards arrived from JLCPBC and the quality is excellent. Although the simplest board ever, with costs so low these days, I thought I'd check out JLCPCB and keep things tidy at the same time...
Tested code on Git and as I manage to reverse the LCD connector, I used some ribbon cable instead of soldering the LCD directly (which also has some advantages)... everything is working fine so far...
