Version 2 of Code
A project log for Control Media player with Pro Micro
Control the Mpxplay Media player with just a Pro Micro, Rotary Encoder and a little Nokia 5110 display... (any OS including DOS)
michael-otooleMichael O'Toole 06/01/2020 at 21:590 Comments
Rather than keep updating I have added the latest edits to code in a new file.
This version is complete except for Enter Key (play track) as I haven't decide which way to do it but even so, if you change the key mapping you have a media controller for any PC running any OS, simply remap the keys to suit...
Set: Volume, Bass, Treble (and Surround Sound if available on your player), select track to play (actual enter key requires work... not sure if I will use the long press or add a dedicated play button)...
Mike
