Adding switches
A project log for Field Ready-TRIO UV 365-395nm Curing Light
3 watt White LED, 9 watts 365nm UV and 9 watts 395nm UV. All in one tool built for Field Ready use.
josh-starnesJosh Starnes 07/08/2020 at 01:350 Comments
Fitting the step up power supply to the  LEDS and Bulb, but I need to wire in the two switches as well.
