Materials:
 1 PCB: JLCPCB
 2 Components: LCSC
 3 PCB Design: EasyEDA
Step 1: Notes:
1 The program is compiled using the ARDUINO IDE and some libraries need to be installed.
2 Node MCU 1.0 (ESP-12E Module) should be checked when using the arduino IDE to download the development board.
3 Some of the API calls in the program, are free to apply for their own.
4 Wifi killer cannot be directly used, because IC pin definition is different, need to modify the source code after brushing in, the modified firmware in the engineering annex.
5 USB serial port chip USES CP2102, need to install the corresponding driver.
Step 2: Improvements
