Sizing kit for UCPLA and Vacuum Tables
A project log for UCPLA RGB Mood Expression Light Controller
An adaptive hand operated RGB Light controller for mood expression, ,YES or NO questions and fun!
josh-starnesJosh Starnes 07/08/2020 at 06:310 Comments
so as you saw in the last update I have made scaled versions of the model in 3 percent increments. These are the vacuum tables to make the first prototypes. I emailed hackaday about getting UCPLA to test out the blob controller and how they would like to do that, and I can send them this sizing file so they can print the general range of mask frames to custom fit their CP individuals. Also I realize that sometimes developmental issues happen resulting In deformity. In this case thermoplastic sheets can be warmed in hot water or blow dryer and shape adjust so it is perfect to that person.
