Non-standard LED driver
A project log for No-Face-Touchy Training Collar (No Magnets!)
An ultrasound collar that helps the wearer break their unconscious habit of touching one's own face by blinking a warning light and beeping
bornachbornach 06/06/2020 at 16:140 Comments
The LED driver circuit is not the recommended way one would typically control an LED array using the a microcontroller GPIO pin. The current limiting is achieved by keeping the NPN BJT (C945) in its linear region by using a 18K ohm resistor on the base. This saves us a current limiting resistor but results in more heat dissipation by the BJT.  I didn't really need to do this, but I just wanted to see if such a setup would work. Might come in handy if your parts bins lack resistors of the required value for current limiting.
