problem solved!!!
A project log for HDD Delta Robot
This is the attempt of building a delta robot using parts from HDD and my parts bin, I'll go as far as I can.
omarOmar 08/27/2020 at 06:390 Comments
Hi!!, problem solved, the xtime composer have connection problems with DBUS, for this reason xtime composer IDE can't see the messages from udev about the connection/disconnection of the startkit, details about how it was solved will be HERE posted by me with the user name Sodor, it's waiting to be approved by a moderator so it can be published tomorrow. Now I can continue with the power stage board (I almost finish it).
