4 pounds 5 ounces, it is light considering everything that is on here! In retrospect in the future I would do the prefiltering and the voltage dependant resistors and capacitors on the ground before the tether. It is not as effective because over the length it is possible to absorb noise agian, but I think it would save maybe 6-8 ounces with that one change alone.
