Today I took the big dip in opening up the actual Pip-Boy kit and looking at the parts in-hand. I've been theorycrafting for a while now, but no plan survives the real world, right? There's also this tendency I have to over- or under-estimate the size of an object when I buy it online. Which, for that exact reason, is why I decided to use a grid for the following pictures. These squares are 1x1cm.
As discussed in My Plan, the Rad Module would indeed be the Raddest of modules, at it would house the Artemis Nano board, along with a Motor Driver and an X27 motor. I don't have the X27 motors in hand, but I could already do some preliminary fitting with the stuff that I had at hand.
Here's an outline of the parts that make the body of the Rad Module:
