So I spent the better half of my weekend fidgeting with the OLEDs and the HoloTape Module!
I initially bought some I2C OLEDs with their headers already attached from AliExpress, and my skills at de-soldering these pins are abysmal to say the worst. Furthermore, me manhandling these small pieces of electronics have already cost some of these (albeit cheap) screens to die from having their ribbon cable ripped from their pads. Yeah... So I ordered a couple (5) new ones from AliExpress that didn't have those pins pre-installed. I tried adding some JST connectors, but those ended up being to bully. 90 degree pins with dupont connectors also didn't fit, so I spent a good couple of minutes soldering wires to the OLEDS.
I removed the OLED screens from their adhesive backing and spaced them out so both of the screens would touch the back of the plastic display.
This way I could cover almost all of the holes for the date/time display.
After I was sufficiently happy with the approach I took, I used electrical tape to protect the soldering points, and provide some structural support for the wires. I then hot-glued it all together to a singular module with 8 wires sticking out.
Ideally I would have daisy-chained them with Qwiic connectors, but those connectors added too much bulk so I wouldn't be able to get the OLEDs to line up properly.
The Fitting
Now that I have my "OLED Module" done (oh I just remember I have to test the screens!), I had to find a way to put it all in the module without interfering with the tape ejection mechanism. After a couple of fittings and looking at the manual, I decided to cut some holes in the bottom, in some raised parts on the bottom of the module:
