• 1
    Make the PCB
    Use the gerber files to order the PCB from the company of your choice. You'll also find the schematics that will allow you to modify some aspects and route your own PCB if wishes.
  • 2
    Order the components and solder
    You'll find the BOM that you can use to make the order. Some of the components are pretty small and will require some skills.
  • 3
    Flash the bootloader
    Connect the board to a PC using a STlink in order to flash the MCU with the bootloader file.
