Running Processes
A project log for Hacking the Vodafone Huawei R201
Tearing apart this portable wireless mobile device!
thetechtokerthetechtoker 06/19/2020 at 22:010 Comments
  PID  PPID USER     STAT   VSZ %MEM %CPU COMMAND
  953   720 root     S    17020 21.1 81.2 /dlna/twonkymediaserver -inifile /var/twonkymedia-server-default-huawei.ini
 4936  1373 root     R     2776  3.4 12.5 top -n 1
  948     1 root     S    85996107.0  0.0 call
  748     1 root     S    39444 49.1  0.0 xmlreporting
  738     1 root     S    37552 46.7  0.0 httpd
  650     1 root     S    37376 46.5  0.0 cms
  662     1 root     S    36760 45.7  0.0 atserver
  669     1 root     S    36548 45.5  0.0 ui_main
 1062     1 root     S    36524 45.4  0.0 upnp -D -L br0 -W rmnet0
  918     1 root     S    36476 45.4  0.0 /bin/wificonnect
  890   888 root     S     5364  6.6  0.0 /bin/hostapd_wps /tmp/hostapd.conf
 1508  1323 root     S N   4880  6.0  0.0 smbd -D
 1323     1 root     S N   4760  5.9  0.0 smbd -D
 1327     1 root     S     3604  4.4  0.0 nmbd -D
  621     1 root     S     2780  3.4  0.0 /usr/sbin/telnetd
 1373   621 root     S     2780  3.4  0.0 -ash
  634     1 root     S     2780  3.4  0.0 /sbin/getty ttyMSM2 115200 vt100
    1     0 root     S     2776  3.4  0.0 init
  661     1 root     S     1720  2.1  0.0 atproxy
  832     1 root     S     1716  2.1  0.0 /bin/dnsmasq -i br0 --conf-file=/var/dnsmasq.conf
  730     1 root     S     1668  2.0  0.0 atcsms
 1064     1 root     S     1636  2.0  0.0 lld2d br0
  722     1 root     S     1592  1.9  0.0 syswatch
  633     1 root     S     1588  1.9  0.0 mic
 1115     1 root     S     1584  1.9  0.0 dhcpc -i rmnet0 -I rmnet0
  720     1 root     S     1572  1.9  0.0 /dlna/twonkymedia -inifile /var/twonkymedia-server-default-huawei.ini
  825     1 root     S     1544  1.9  0.0 dhcps
  372     1 root     S <   1516  1.8  0.0 /sbin/udevd --daemon --debug
  644     1 root     S     1336  1.6  0.0 diag_switch /dev/ttyMSM0
  888     1 root     S     1332  1.6  0.0 /bin/hostapd_wps /tmp/hostapd.conf
  864     2 root     SW<      0  0.0  0.0 [ksdiorqd]
  850     2 root     SW<      0  0.0  0.0 [AR6K Async]
  767     2 root     SW<      0  0.0  0.0 [USB mass_storag]
    5     2 root     SW<      0  0.0  0.0 [events/0]
  113     2 root     SW<      0  0.0  0.0 [smd_tty]
    4     2 root     SW<      0  0.0  0.0 [watchdog/0]
  315     2 root     SW<      0  0.0  0.0 [mtdblockd]
  140     2 root     DW<      0  0.0  0.0 [rpcrouter]
   91     2 root     SW<      0  0.0  0.0 [kmmcd]
  744     2 root     SW<      0  0.0  0.0 [usb_work]
  185     2 root     SW       0  0.0  0.0 [pdflush]
  645     2 root     SW<      0  0.0  0.0 [mmcqd]
    6     2 root     SW<      0  0.0  0.0 [khelper]
  150     2 root     SW<      0  0.0  0.0 [ctl0]
    3     2 root     SW<      0  0.0  0.0 [ksoftirqd/0]
    2     0 root     SW<      0  0.0  0.0 [kthreadd]
   10     2 root     SW<      0  0.0  0.0 [suspend/0]
   80     2 root     SW<      0  0.0  0.0 [kblockd/0]
  110     2 root     SW<      0  0.0  0.0 [modem_notifier]
  126     2 root     SW<      0  0.0  0.0 [qmi]
  133     2 root     SW<      0  0.0  0.0 [nmea]
  146     2 root     SW<      0  0.0  0.0 [krpcserversd]
  154     2 root     SW<      0  0.0  0.0 [ctl1]
  158     2 root     SW<      0  0.0  0.0 [ctl2]
  183     2 root     SW       0  0.0  0.0 [pdflush]
  186     2 root     SW<      0  0.0  0.0 [kswapd0]
  189     2 root     SW<      0  0.0  0.0 [aio/0]
  338     2 root     SW<      0  0.0  0.0 [kondemand/0]
  341     2 root     SW<      0  0.0  0.0 [rpciod/0]
