v2.1 has been release a few days ago but i somehow forgot to promote it:
Changelog:
- update kiplot to kibot v0.7.0
- *.kiplot.yaml files now have to be called *.kibot.yaml!
- path of pcbdraw changed, please use:
style: '/usr/share/pcbdraw/styles/jlcpcb-green-hasl.json'
libs: ['/usr/share/pcbdraw/footprints/KiCAD-base']
- using docker image
setsoft/kicad_auto:10.4-5.1.6
instead of including all packages by myself - enable verbose output in CI runs
- add codefactor.io
- fix file permissions
I am currently already working on v2.2. As kibot 0.8.0 is currently in the pipeline this is something I am waiting for and it will enable some nice things. Additionally I am working on more predefined config files which will generate outputs fitting special needs, eg a BoM in a format compatible to JLCPCB or plotting PCB renders in oshparks famous purple/afterdark colors. so stay tuned!
