​Onboard Gateway - Electronic Components
A project log for 2021 HDP Dream Team: EJA
Learn more about Team EJA's intelligent buoy, and how their solution will help the global fight against ghost gear.
leonardo-wardLeonardo Ward 08/05/2020 at 15:240 Comments
The buoy transmits its position using LoRa, therefore it is necessary to create a device that the fishers can carry with themselves that receives the position data (using LoRa). This devices also creates a WiFi network and streams the data through it, a phone will be used to access this local network and visualize the data (using an app).
Similar to the buoy design, we considered different alternatives that were able to meet the requirements and then selected the best one, and selected the most appropriate ones.
Main Components
