Onboard Gateway V.10 - Bill of Materials
A project log for 2021 HDP Dream Team: EJA
Learn more about Team EJA's intelligent buoy, and how their solution will help the global fight against ghost gear.
leonardo-wardLeonardo Ward 09/18/2020 at 18:300 Comments
This log presents a price of each one of the elements related to the electronics of the Onboard Gateway V1.0. The following table presents the price per unit and the price per 1000 units for each component, taking into consideration the changes in the price per unit when bought in groups of 1000 units.
PCB Components
NamePrice per unitPrice per 1000 units
PCB$0.50$767.00
TERM BLK 2P SIDE ENT 5.08MM PCB$0.80$205.20
CONN HEADER R/A 2POS 2.5MM$0.18$80.68
CONN HEADER VERT 40POS 2.54MM$2.29$1,272.00
CONN HDR 6POS 0.1 TIN PCB$0.52$265.82
USB LiIon/LiPoly charger$12.50$10,000.00
RES 249 OHM 1/4W 1% AXIAL$0.10$11.00
CONN HDR 2POS 0.1 GOLD PCB$0.33$157.50
CONN JUMPER SHORTING .100" GOLD$0.10$26.46
CONN HDR 19POS 0.1 TIN PCB$1.17$643.68
ESP32-DEVKITC-32D$10.00$10,000.00
CONN HDR 16POS 0.1 TIN PCB$0.98$541.44
CONN HDR 12POS 0.1 TIN PCB$0.78$432.00
CONN HDR 9POS 0.1 GOLD PCB$0.67$368.64
RES 100 OHM 3W 5% AXIAL$0.71$264.44
CONN HDR 5POS 0.1 GOLD PCB$0.47$243.54
RFM95W LoRa Radio$19.95$19,950.00
External Components
Lithium Ion Battery - 3.7v 2000mAh$12.50$11,250.00
Micro USB Board$2.50$2,500.00
LED ASSORTED RESISTOR 5MM 20PK$9.69$9,690.00
DP OFF-ON TABS M12X0.75 DC$3.40$2,270.00
Overall Price
$84.34$72,592.60
