LED driver - PCB Design
A project log for UVA
High-power ultraviolet flashlight for curing UV adhesive (https://bit.ly/FldRdy-DB)
said-alvarado-marinSaid Alvarado Marin 10/05/2020 at 09:220 Comments
In this short log were are going to talk about some of the consideration taken into consideration when designing the PCB for the High efficiency Led Driver.
High Efficiency LED driver PCB
AL8853 datasheet recommendations
Thankfully, as with many integrated circuit nowadays, the AL8853 Led driver datasheet has a handful of  recommendations layout. In this case they are pretty basic:
  1. Keep traces thick and short.
  2. Keep capacitors and resistors as close as possible to the IC.
  3. Keep delicate signals away from inductors.
  4. Make sure these high current loops are as short as possible.
The loops they are talking about are these ones:
Power loops of the AL8853 driver
image taken from the AL8853 datasheet
Which in our PCB, correspond to the following traces:
Power loops highlighted in the PCB
Which realistically speaking, are about as small as I could feasible make them.
A word about EMI transmission
I do not know much about PCB design in general. But in this excellent resource over here, they recommend the practice of via stitching to minimize the amount of electromagnetic interference your board will generate.
So if you check the Kicad project for this board and wonder why there are so many random vias everywhere. This is the reason.
