This is a very early days in the project but what the features i would like RISC-VLAD are:
  • Display: at least the pixel area of the original GameBoy 160 × 144 pixels, 47 × 43 mm.
  • Buttons: that are responsive and comfortable to use.
  • Audio: can be DAC or PWM based either is acceptable.
  • SDcard: slot for storing extra sprites game code ect.
  • Power: Needs to be portable (batteries or can run from USBpower stick)
  • Programming: Be able to be programmed without additional hardware (Very important)
Optional:
  • Rechargeable power system onboard.
  • Wifi
  • BLE
  • USB
I have initially selected the GD32VF103RBT6 as the MCU which has a 32bit RISC-V based Processing core. This however may change as other options become available.
