These LiteOn LTP2558AA LED modules came from the local surplus shop (www.elliottelectronicsupply.com/featured/liteon-ltp2558aa-ra-large-2-4x1-5inch-dot-matrix-red-orange-and-green-leds-gray-face-with-white-dots-in-off-state.html). They have a LOT of these beasts in stock. Usable data sheets were found on the LiteOn web site.
LiteOn LTP2558AA LED Module With a Familiar Object for Scale Reference.
This is my first dive into matrix LED stuff. Driving them seems a little bit like driving a video display, but only sort of. I looked at options for driving them from raw drivers and a SPI interface to fully integrated controller/driver chips. In order to support the red and green LEDs, there are two separate sets of row and column pins on each module. Each of the matrices has its own driver chip. The ISSI IS32FL3738 chips support up to a 6x8 matrix, provide current control and dimming options and two of them will fit on a PCB that sits under each module. They are also readily available and fairly inexpensive. I roughed out an electronic design and laid out a 4 layer PCB to mess with.
Rev 1 Driver PCB test fit on the back of an LED module.
The boards came back from OSH Park and I built up the first one. The two LED controller chips are visible in the center of the board and the I2C address translator (LTC4316) at the lower left corner. The I2C bus and sync signal will route from module to module via the connector on the lower left edge of the board. Power connections will be done in a star configuration ending at the power connector above the bus connector.
From the IS32FL3738 data sheet, it sounded like I needed direct routing from the driver outputs to the LED module pins due to current requirements. The driver chips require half a dozen or so passive components. In order to minimize the routing interuptions, I put the passive components on the back side of the board. There are ground/heat sink pads on the bottom side of the driver chips. In order to get a good solder connection to the pad, I populated the top side of the board and reflowed the solder on my hot plate. The passives on the back side got installed and hand soldered which is a pretty fiddly process.
The rev 1 board was designed with address translation on the upper 3 bits only, with one translation configuration resulting in an undesirable address (0) for the red controller.
In order to simplify the build and get address translation on both the upper and lower nibbles of the address, I did an iteration on the board design. All of the passive components got moved to the top side of the board. I also narrowed the board slightly so that the board fits completely under the module. The new boards have been sent out and should be returning from OSH Park early this week.
Documentation on the IS32FL3738 chips is pretty terse and this is the first time I have messed with them. In order to figure out how to drive the chips, I used a PC based USB to I2C dongle (TotalPhase Systems Aardvark) and a tool that I wrote that accepts text file input and drives the I2C bus. I roughed out a minimal initialization sequence for one of the driver chips and got fairly close. It took a couple of hours of experimentation to get the first LED to turn on. Then I progressed to controlling multiple rows and columns and getting the green controller operating. The red and green LEDs look yellow when both are lit.
In order to generate the data for actual characters, I wrote a tool in Labview to take LED on/off data from a GUI and output it as a .csv file formatted for the LED ON/OFF registers on the IS32FL3738 chip. Labview is a good tool to generate GUI interfaces quickly for me. The bit manipulation and data handling capabilities adequate for this type of work.
The IS32FL3738 chips support a 6x8 matrix, but I am only using a 5x8 matrix. I included the extra column and data in the output for completeness. The tool supports reading an existing data file for editing. Click on a dot in the matrix to turn that LED on or off in the data output. Once you have a pattern that you like, press the append button and it will write the data for that character to the output file. Selecting the character is done with the "HEXVAL" window to the left of the buttons. That value goes into the output data as well.
Starting from the character shapes used by an old HP display, I did a first pass on a character generator. Data from the character generator output was copied into the test scripts mentioned above, and I found out that I had generated the characters upside down. After flipping the characters and fixing the tool, it looks pretty good.
The original character display used a 5x7 matrix, while the new modules support a 5x8 matrix. I put the characters in the upper 7 rows and used the bottom row for "descender" characters like g, p, and q to make them look better.
At this point, I built up the remaining two display modules and tested the address translation. All works as expected. I also made an aluminum plate to mount up to 9 of these modules to and a wiring harness to connect the I2C between modules.
First 3 Display Modules on the Mount Plate
In order to actually use these modules in a project, I wrote a low level display management library in C. The machine specific I/O stuff is completely encapsulated in one file, so I can develop it on my PC with the Aardvark for I/O and then replace the I2C drivers with ones for whatever MCU gets chosen for the first project.
The display management library allows scrolling in either direction, character by character color control, and global display brightness control.
