Making the Adafruit CLUE multi-functional!
A project log for Cutebot and CLUE are even better pals!
Building a library to allow Adafruit's CLUE and ElecFreak's Cutebot to communicate while maintaining all the functionality of the CLUE.
jtJT 08/13/2020 at 18:310 Comments
I added a nifty startup menu to make the Adafruit CLUE multi-functional. You no longer bounded to one program or need to rename your files to code or main to run them. Simply drag and drop your files into your CIRCUITPY drive and this menu program does the rest.
