Serial
A project log for Projector Control
Adding WiFi to a 15-year-old LCD projector
andy-castilleAndy Castille 08/09/2020 at 03:021 Comment
But where to start? I had no idea how to use this port. Luckily, I wasn’t the first to try this. I found “Projector Controllers for Sanyo Projectors”, an old SourceForge project, that attempted to do the same thing. This told me that the service port was an 8-pin mini-DIN serial port. As for my specific model, I found several “serial command manuals” (such as this one for the Sanyo PLC-XU106) that detailed the serial protocol and commands. They were all similar enough (differing only in the number of commands available, which makes sense given the different models have different features) so I assumed the basic on, off, and input switching commands would work with my projector.
8-pin mini-DIN breakout connectorUsing this knowledge, I found and ordered a breakout connector (shown and linked above) that would let me use such a cable into with my microcontroller boards, and a serial cable to go between it and the projector’s service port.
My projector’s manual did provide a little bit of useful information: the service port pin numbering and assignment (shown below)
Service port pin numbering
Combining this with the datasheet for the breakout connector from Mouser, I created this mapping table:
ProjectorNumberColorArduino
RXD1BrownTX (3)
2White
3Black
GND4Blue
RTS/CTS5Green?
TXD6YellowRX (2)
GND7Orange
GND8RedGND
Despite the presence of an RTS/CTS line, the manual says that flow control is not needed.
Now I had everything I needed to communicate with the projector using an Arduino Uno I had laying around. I wrote the following sketch to be able to write my own data out and receive incoming data while sending the required CR between commands:
#include <SoftwareSerial.h>
SoftwareSerial projector(2, 3);
char buffer[64];
byte index = 0;
void setup() {
  Serial.begin(19200);
  while (!Serial);
  projector.begin(19200);
  while (!projector);
  Serial.write("Ready\n");
void loop() {
  // Projector -> PC
  if (projector.available()) {
    Serial.write("RX: ");
    while (projector.available()) {
      Serial.write(projector.read());
    Serial.write('\n');
  // PC -> Projector
  while (Serial.available()) {
    char c = Serial.read();
    if (c == '\r' || c == '\n') {
      // Send buffer to projector
      projector.write(buffer, index);
      projector.write(0x0D);
      // Echo buffer
      Serial.write("TX: ");
      Serial.write(buffer, index);
      Serial.write('\n');
      // Reset buffer
      index = 0;
    } else {
      // Add to buffer
      buffer[index++] = c;
But did it work? No. I sent many commands through the serial console and got left on read an equal number of times.
To figure out what was going on, I hooked up a logic analyzer to all of the lines and recorded sending messages from the Arduino and waiting for a response, as shown here:https://serial.rodeo/posts/projector-control/cr02.pngI’m not sure what the ‘255’ on the GND line was from, but I’m assuming it was just crosstalk due to the cheap breadboard I was using.
After another couple hours of trying different combinations of wires and serial data, I figured it must be the incorrect voltage. The Arduino was only communicating with 5 volts, but RS-232 could go much higher. If the projector was expecting 12 volts, it wouldn’t count 5 volts as a signal. Before sending higher voltages into my projector without knowing, I decided to email the person behind the Projector Controller project on SourceForge that I mentioned earlier. I figured it was a long shot that the email was still valid because it had been 10 years since the project was last active, but I was desperate.
I sent an email asking about what voltages were tested and working, and to my surprise, I got a response, and quickly! The relevant part:
Its been a while since I looked at this. In my circuit I used a max232 level converter chip, so I’m guessing its 12v. It should be reasonably safe to try this. In my other software project I would have used a usb to serial converter which also would likely be 12v.
Looks like I was right. Unfortunately, the level converter chips aren’t cheap, and I had already spent about $15 on this project, so I assumed I was probably nearing the cost of a new remote and decided to give up. But wait…remotes? I already had an input to the projector that works, I just need something besides my remote to use it!
What comes in packs full of matching pairs for about half the price of a MAX232 chip? IR diodes just like the one in my remote. Into my cart they went.
Stay tuned to find out what happens when they arrive!
Martin Kleinhans wrote 02/05/2024 at 09:38 point
Super helpful post, thanks for the detailed documentation.
In the end, I had the same issues as you, and it turned out the solution is quite simple:
The projector expects us to send [CR] AND [LF]. The documentation is super misleading, it only talks about [CR].. but once you add the [LF] at the end, everything just works. :)
