Using PET's flex for a self-locking tail
A project log for Propel-E 50 | A powerful recycled windturbine
A windturbine made from PET-bottles! Completely 3D-printable and open-source.
bram-peirs-fw2wBram Peirs @ FW2W 08/24/2020 at 16:370 Comments
We aim to make the construction of the windturbine as easy as possible. This means a minimum of glue and screws. For the tail, we designed a piece that holds 3 aluminium rods and can be mounted on a 40mm pole. Since the rods and the PET flex a little, they will interlock because of the tension of bending the rods towards eachother:
Test print, but gives a more detailed view:
