Finished the mechanical part an made some testruns. Had some problems with stucked pellets and added a second heat band. Also needed to reduce the inner diameter of the nozzle.
The Problems with burned filament are now gone.
Will add a second temperature controller and change the gear ratio as well as the hopper design.
