Software Examples
A project log for 68K CPU with Frame Buffer on FPGA
Working with AMR's build and improvements to the TG68 FPGA project
land-boardscomland-boards.com 09/06/2020 at 21:170 Comments
Code
AMR has several code examples. I've added some documentation and comments to the code. If you try them, make sure you are on the master branch of AMR's code. I've also got the code in my Linux repo.
HelloWorld
Prints out strings and numbers on the UART serial port using printf.
Rectangles
I added these comments to the source code
// rectangles.c - Draws rectangles on the VGA screen
// random size rectangles
// combined with previous rectangle colors
// scrolls screen vertically as well
// scrolls on vert sync interrupt
// very busy screen
// bootloader leaves debug window up
FrameBufferTest
Graphics test with sprite under PS/2 mouse control.
