Bootloader and SD Card
A project log for 68K CPU with Frame Buffer on FPGA
Working with AMR's build and improvements to the TG68 FPGA project
land-boardscomland-boards.com 01/16/2021 at 14:080 Comments
Boot Process
The code has a bootloader which loads the executable program from the SD card. The bootloader code runs from ROM on the FPGA.
SD Card Image
The SD Card contains a single file, boot.sre . This file is run automatically when the card is powered on.
The image is an S record. The SD card is a FAT32 formatted card.
