26.11.2020 - Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulleys
A project log for Voron Switchwire 3D Printer
Voron Switchwire - DarekNorway Build Log
dareknorwayDarekNorway 11/26/2020 at 11:180 Comments
Components list: https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulleys - Front View
Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulleys - Side View
Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulley Block - Right
Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulley Block - Left
Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulley Blocks - Printed Parts
Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulley Blocks - Assembly
Idler Pulley Stacks: Spacer+Bearing+Bearing+Spacer+Spacer+Bearing+Bearing+Spacer
Bearings: Rain&Dew F695-2RS Bearing 5*13*4 mm ABEC-7 Flanged
