I had to revert KICAD back from nightly build to stable and lost a pqart of the work because of file down compatibility issues. I had to redo the routing.
Here is the first experimental schematic diagram (still some work to do). Until I get a Compute module 3, I will use the RPI PI ZERO W computer.
Next step tomorow
