The provided STL files were designed to fit my Dell OptiPlex 7760 All-In-One, but the editable TinkerCAD design is available so you can tweak it to better fit your monitor.
This is a simple 3D printed teleprompter that reflects part of your computer screen directly in front of your webcam
Standard Tesselated Geometry - 20.20 kB - 10/18/2020 at 21:35 |
Standard Tesselated Geometry - 15.12 kB - 10/18/2020 at 21:35 |
These parts were designed to fit my Dell 7760 All-In-One but you can modify the editable TinkerCAD design to make it fit snugly on your computer.
Lay these parts out with the 4"x6" plexiglass and mirror you bought. The mirror I bought had rounded sides, it doesn't matter if yours does or doesn't. Also I purchased PETG plexiglass but any clear material should work.
Or use it during video conferencing to look directly into the camera and maintain eye contact with the person on the other end of the call!
That’s great!
I thought your project was a computer monitor for zoom meetings where you can look at your desktop, rather than an awkwardly positioned webcam, but I guess a “teleprompter” would be directed at “prompting” people to say something. I guess I’m trying to make a “holographic” monitor with a camera behind the desktop screen (mounted to a computer desk, not portable).
Do you think there’s a way to use an ultra-short-throw projector to project a desktop onto a high-angle reflective screen, or lens, so that the reflective screen won’t take up so much space in front of the viewer while the webcam is behind the screen (like in a typical teleprompter)?
That sounds like a great idea! I wonder if making a monitor-sized version of this device with a bright monitor would accomplish what you want? And then you'd mount the camera right in the center of the screen?
This device reflects a small area (4"x6") of the monitor upwards in front of the webcam, you basically want to reflect the entire thing? Like a Pepper's Ghost illusion for your monitor? https://en.wikipedia.org/wiki/Peppers_ghost
I've seen a lot of designs for teleprompters, but this one seems great. Although personally, I have a thing about anything being between my screen and my eyes -- if so much as a jumper wire from a breadboard visually overlaps my field of view I get uncomfortable. I feel like this would drive me nuts unless I devoted a dedicated monitor to it.
But that's just me, still a great design. Thanks for sharing, Lex!
Thanks Dan! After a week of trying to use it on conference calls I can confirm that it takes some getting used to. One issue is that the optical quality from the plexiglass and plastic mirror I used is passable but not great. I bet this aspect could be improved a lot with higher quality optical parts. I also found it awkward to use while screensharing in Zoom as the teleprompter covers the middle of the screen so I had to move the applications windows around it. The place I think it works best is for reading teleprompter text into the camera when making a tutorial video or something like that.
I wrote a completely free HTML/Javascript version of a teleprompter app, and included the source code for those interested in changing it...
https://hackaday.io/project/178618-entirely-html-simple-teleprompter
