Implementation of new cable bushings
A project log for CHANGER - a toolchanger new interpreted
CHANGER - a motion system which can be used for advanced 3D-Printing with up to four materials, PnP, PCB-Milling, Layer inspection, etc...
simon-wirzSimon Wirz 03/08/2022 at 15:050 Comments
As mentioned in the previous log I've designed a cable bushing to prevent the cables from taking damage due to vibration over the lifetime of the printer.
-> https://hackaday.io/project/175489-changer-a-toolchanger-new-interpreted/log/203818-improvement-of-the-cable-openings
I've printed the mainframe in PLA and the three individual bushing with TPU (middle-soft)
Printing the TPU-parts:
Some parameters:
240°C (1st Layer 250°C), 30mm/s (1st Layer 15mm/s), 0.2mm layer height
Final assembly of the cable-bushings
It's not perfect (I could have switched the + and - of the 12V OUT so that there is no twist but I've noticed that to late in the process. But afterall I'm quite satisfied with this style of cable-bushing with the TPU-innerpart for better cable protection.
