I am planning on redoing this and adding reverse polarity protection with diodes too protect pedals that get plugged into the wrong polarity and maybe adding more current capability.
A project log for EuroRack 9V/12V Pedal Regulator Breakout Board
Allows You too Run Pedals or Circuit bent toys off your main 12v power supply in a Eurorack setup.
