A busy/free desktop indicator for the Adafruit Circuit Playground Express. Red shows you are busy and for how long, blue shows you are free!
Bring in the New Year in style... the Holiday Wreath shader has been replaced with a Fireworks shader! See the sparkling explosions from the safety of your desk.
Added a new holiday wreath shader to celebrate the holidays!
Also, I've tested the Busy/Free Desk Indicator with CircuitPython 6, and it doesn't like having the Circuit Playground's filesystem mounted in read-only mode. If you would like to use CircuitPython 6 then omit boot.py when installing the software - otherwise stick with CircuitPython 5.3.
Now you can rotate through different LED animations by pressing the B button while idle! I'm still a fan of the original "rotate" animation tho...
Copy adafruit_lis3dh.mpy
and simpleio.mpy
from the CircuitPython Library collection into the
