Test of power
A project log for MultiBot CNC v2
A low cost 3D printed CNC that can be built with minimal tools yet is capable of great things.
david-tuckerDavid Tucker 02/02/2022 at 04:260 Comments
So with a new laser on the way I have been thinking of how best to compare my old 30w (7w optical) laser with the new 40w (15w optical) laser.  In addition I would like to compare it to a low end CO2 laser like a K40 or Glowforge.  I have not checked them out yet but my local makerspace has a few lasers that look like good candidates for comparison.
For starters I have been trying to find examples online of peoples settings when they cut through various materials.  This sounds like a good idea but most of the data out there is sketchy at best.  I have a feeling a lot of it is just made up, or loosely recalled rather than based on facts.  And the ones that are factual are usually woefully incomplete.  Often you get a speed without knowing the number of passes or laser power setting.  If you do get good data then you can work out the actual cut speed by taking the cut speed and dividing it by the number of passes.  So 500 mm/min with 8 passes is only about 62 mm/min in cut speed.
It would be nice to directly measure the optical power of all the machines.  I can use my old laser calorimeter test to compare the relative power of each machine.  I probably need to increase the size of the target material and come up with a better holder for it.  And it would be nice to get an IR thermometer with a better range and some sort of a min/max function.  If this was capable of measuring the power of a CO2 laser then it could not only tell us how linear the output power is on a CO2 laser, it could also give us a good idea of how much more raw power a CO2 laser has.
The real test is to try and cut some different materials and see how deep the cuts can get.  This is made extra hard because there are many variables at play, making it hard to come up with an optimal set of parameters without a lot of experimentation.  Here are some of the factors at play.
The author of LaserGrbl put up this video showing a way to estimate depth of cut of different lasers by doing an incline test as a way to measure the thickness and height of the waist of the laser beam.  I'm not sure how well this works, but it is something to experiment with.
It would be nice to know exactly when we are focused at the top of the material.  That way we can run tests with the laser raised and lowered from that point to see if the cut depth or quality is affected.  To help this along I have ordered a $18 usb microscope and some black anodized aluminum cards to focus on.  I also picked up some clear yellow plastic to try and cut the blue light from the laser to help the microscope better see the spot.
Finally I plan on picking up several different samples of hard and soft wood from the hardware store for comparison. My hope is to pick a few strong contenders and then cut 1-4 passes in each with the most optimal parameters for each laser to see how deep and fast we can cut. This part is rather fuzzy in my mind, hopefully it becomes more solid over time.
