The project was to enlarge the hole in a piece of hardened steel. The existing hole is what made the project so simple. The idea is to move electrolyte through the hole while passing a DC current through it. The metal surrounding the hole will be dissolved into the electrolyte thereby enlarging the hole. A jig was made that would keep the electrolyte from reaching any part of the workpiece that wasn't intended to be removed. The setup is shown below:
Figure 1
The workpiece is a wrench which is clamped to a piece of wood.
The jig is attached to the far end of the wrench.
There is a pail to catch the electrolyte after it has passed through the jig.
Note the plastic tube which leads to a 20 litre bottle of salt water. The tube is a siphon.
The spring clamp is used to pinch off the syphon.
The positive terminal of a 24 volt power supply is clipped to the workpiece (ie. the wrench).
The negative terminal of the power supply is clipped to the copper tube that feeds the electrolyte to the jig.
Figure 2
This is a section drawing of the jig.
Note that the end of the copper tube stops short of actually touching the workpiece. Otherwise, a short circuit would result.
Figure 3
This is an exploded drawing of the jig.
The gaskets are rubber tape with ragged 8 mm holes drilled in them.
The tape at the bottom of the jig has a 3 mm hole drilled in it. It's purpose is to reduce the flow of electrolyte and to ensure that the electrolyte establishes proper electrical contact with the workpiece.
Results
The current was about 0.6 amps throughout the job which lasted about an hour. The power supply output was 24 volts. The hole in the wrench was enlarged from 7.5 mm to 9.5 mm. The hole is not particularly circular. Its diameter ranges from about 9 mm to about 10 mm.
Discussion
The biggest surprise was that the hole's edges were quite sharp. My reading led me to believe that sharp edges are hard to achieve with ECM. One possibility is that the paint on the surface of the workpiece would overhang the edge for a while before collapsing thus reducing the electrolyte's access to the edge.
Normally, the gap between the tool and the workpiece is quite small. In this case the distance between the end of the copper tube and the workpiece was at least a couple of mm. That reduced the DC current thus increasing the machining time. It probably also decreased the accuracy of the machining.
The thick rubber gaskets appear to have deformed when the jig was assembled. That would also have affected the accuracy of the machining.
Since the hole is contained within the jig, it was necessary to calculate the machining time to determine when to stop.
I calculated a machining time of about an hour. When the job was done and the jig was disassembled, it was found that the hole was about the right size. The problem is that I found an error in my calculation. The job should have taken twice as long.
Is it possible that the formula is wrong for this case? The calculation was close to the actual result. I thought I found an error but that was wrong. That said, I spent some time trying to figure out why the formula might not work.
The spent electrolyte was recycled back into the 20 litre bottle without filtering. Shining a laser beam down a column of that electrolyte produces scattering. That indicates particles larger than a nanometer in diameter.
If the iron is coming off the workpiece in particles larger than a nanometer, that might invalidate the formula.
Another thing is that, because of the wide gap and high voltage, there are plenty of oxygen and hydrogen ions present. That might give rise to a chemical reaction that also strips iron from the workpiece. That might also invalidate the formula.
Given that there are things that might go wrong, the MRR (Material Removal Rate) formula seems pretty robust.
Reference: http://www.home-machine-shop.com/Down-Load/Electrochemical_Machining.pdf
Work process
I'm in the habit of doing calculations interactively in Python. The problem is that it doesn't create a record.I'm going to try using Jupyter Notebook for calculations and note taking. It will export its notebooks in html but that creates a huge file. I'm going to try cut and paste below.
Calculations
The spent electrolyte was put back in the 20 litre pail. The metal is 3.5 mm thick. The starting hole was 7.5 mm dia., 3.75 mm radius. (shr) The ending hole was 9.5 mm dia., 4.75 mm radius. (ehr)#CALCULATE THE METAL REMOVED93.5 mm^3
from math import pi
T = 3.5
shr = 3.75 #starting hole radius
ehr = 4.75 #ending hole radius
startHoleArea = pi * shr**2
endHoleArea = pi * ehr**2
volumeRemoved = (endHoleArea - startHoleArea) * T
print(round(volumeRemoved,1), "mm^3")
ccRemoved = volumeRemoved / 1000
print(round(ccRemoved,4), "cm^3")
0.0935 cm^3
The measured current was approximately 0.6 amperes. (I = 0.6)
#CALCULATE TIME REQUIRED0.0013 MRR cm^3/min
I = 0.6 #from above
#ref = https://www.engineeringenotes.com/industrial-engineering/machining/electro-chemical-machining-ecm-methods-machining-engineering/23332#:~:text=In%20an%20ECM%20process%20for,constant%20%3D%201609%20amp%2Dmin.
#Given atomic weight of iron = At = 56 gm
At = 56
#Valency of iron dissolution = v = 2
v = 2
#Density of iron = ρ = 7.8 gm/cm3
p = 7.8
#Faraday's constant F = 1609 amp-min
F = 1609
#Metal Removal Rate (cm^3/min) = MRR = (I At)/(F v p)
MRR = (I * At)/(F * v * p)
print(round(MRR,4), "MRR cm^3/min")
timeRequired = ccRemoved / MRR
print(round(timeRequired,1), "minutes")
69.8 minutes
Because there is light scattering due to the iron particles in the used electrolyte I am curious about the particle size. The maximum concentration of iron in the electrolyte is ccRemoved / (20 * 1000).
conc = ccRemoved / (20 * 1000)4.67e-06
print(round(conc,8))
Given the low concentration of iron particles and the robust scattering observed, that implies a particle size closer to 1 nm than to 1 um (the usually accepted upper limit for colloids). The iron particles seem to have settled out of the electrolyte over the period of a few days. My guess is that has more to do with zeta potential than with particle size.
