For the second try I raised the baking time to 2 hours and added a thin metal sheet on one side of the mold to prevent the plastic from sticking onto the surface. This worked well, but unfortunately, I had only one side equipped with the metalsheed. So the material baked solid on the second side and it was very hard to remove it. Nevertheless the way to go is cleat for the third try....
