Many animals have exited a menu only to find their nozzle temperature was suddenly too cold or their probe Z offset was .1mm too high. For animals who destroyed a print by trying to exit from a menu, the solution is to whack on a separate button instead of using the dial as a button.
The hardest part is drilling through the 2mm thick depleted uranium steel armor that is the front panel.
