Testing the Base, bad news for IR
A project log for X-Mas WTree
Adressable RGB is the answer to your PCB Tree
nicolNicolò 12/31/2020 at 01:040 Comments
The base dimension is perfect, but is a bit light, the tree itself must be glued to the base to keep it loked.
The bad news is about an issues on PCB. For some still unknow reason the IR circuit seems to be broken.
I've asketd a friend to land me a RGB remote to test the feature, but it seems to be not working.
Now I'm not sure if it is an error on the circuit itself or if it is an issue with software.
More troubleshoot time is required.
