Klipper driven ODROID-C4
A project log for Klipper on ODROID-N2/C4
Running Klipper full software stack on ODROID-N2/C4
dongjin-kimDongjin Kim 01/28/2021 at 08:240 Comments
I've finally soldered a couple of components that were missing and attached the control board to ODROID-C4. 4 steppers and BLTouch are running and the print quality is not that bad.
Sliced by Cura at 50mm/s and printed at x300 feeding rate.
