Testing
A project log for PelletMon - IoT for central heating / boiler.
Monitor pellet boiler status via CAN bus, measure fuel usage - RE + engineering = profit !
h4rdc0derh4rdc0der 02/28/2021 at 20:440 Comments
Today I prepared the cables and prototype software to retrieve data, then connected everything to the heating boiler CAN-bus and communication with MQTT worked properly.
Example dasbhoard:
Testing connection and current consumption.
What's next?
I need to route everything properly, get an enclosure and add fuel level sensor. It will take few days as I have to order cable organizers etc.
