After removing the terminating resistor, the problems with the boiler disappeared. The device has been working continuously for several days without any problems.
Final mounting - transparent enclosure, SMA antenna:
A project log for PelletMon - IoT for central heating / boiler.
Monitor pellet boiler status via CAN bus, measure fuel usage - RE + engineering = profit !
