PCBs assembled
02/24/2021 at 20:02 • 0 commentsUnfortunately, I had to wait over a month for the package, but it eventually arrived. Soldering was quick, without hot-air gun.
Anyway, a lot of optimizations have been introduced into my iot framework - ksIotFrameworkLib.
I hope to have some time to launch this board at the destination place in my basement, but it will not happen this week :) -
PCBs in production!
01/03/2021 at 18:33 • 0 commentsSince all experiments were successful, it's time to order a PCB.
All parts were ordered together with the board.As usual, I used the JLCPCB service, combining the order with LCSC. Unfortunately, according to the announcement, the option to combine orders will be withdrawn soon.
Experiment 3 - Better approximation
01/02/2021 at 19:44 • 0 commentsI decided to improve the temperature conversion. Here's where the curve fitting software come in.
One of them is Curve Expert - can be bought at https://www.curveexpert.net/order, but trial is also available.After a few tweaks, the polynomial curve fitting method turned out to be the best (5th degree).
double calctemp(short x) { double a = 1.445633283634090E+02; double b = -1.386947619796149E-01; double c = 9.837913934334235E-05; double d = -4.486094388070098E-08; double e = 1.076415627857750E-11; double f = -1.066640689001453E-15; return a + b * x + c * pow(x, 2) + d * pow(x, 3) + e * pow(x, 4) + f * pow(x, 5); }
It turned out that all temperatures are transferred in the same way, so this function can be used to calculate different temperatures - e.g. domestic hot water.
Experiment 2 - Hacking all I CAN
01/01/2021 at 21:20 • 0 commentsI previously established that my boiler uses the CAN bus to transfer data between the controller and the touch panel. The controller is somewhere inside and the touchpad is on the front as you can see ...
The CAN port is on the back - it looks like an ARK connector. There are also CANL, CANH, GND and optional 12V, so the external module (Estyma VideNET) does not require a separate power supply.
So, let's start hacking...
I quickly realized that I did not have the right tools to analyze CAN traffic, since I had only ESP32 and CAN transceiver module based on SN65HVD230 chip.
I tried several internet solutions to send data to Wireshark, but the messages were still difficult to analyze.
I found a program on the Internet that I can use to suit my needs - CAN-Monitor-3000 github repository. I ended up writing a program in Arduino to emulate one of it's supported adapters.
Visit my Canmon-Sniffer repository!
Troubles with temperature...
After searching the data stream, I found no interesting temperature value.
Then noticed message 0x2D6... it changes when temperature changes!I figured out that I could send the crafted data to the bus. I had to add support for sending data to the CAN bus to the sniffer.
I was in trouble when I sent the wrong frame. The boiler reported a sensor failure and turned off.
But eventually after few hours of headache, I ended with this small lookup table:
Approximate for the win!
I entered the given values on one of the pages for the function approximation. Then I put the given function into the test program.
After uploading the program to ESP32, I got an approximate temperature reading.
There is still a lot of work ahead of me, but this adventure was really interesting.
Experiment 1 - HC-SR04 to monitor fuel level
12/28/2020 at 16:16 • 0 commentsExperiment 1
I've bought HC-SR04 distance sensor and connected it to ESP32 devkit. I was curious if it would return reasonable value, because the fuel has no smooth / flat surface.
Result - suprise! It works!
This is a cool project base then, so I can research further :)
