See Github for most recent status and all results:https://matts-ch.github.io/benchmask/I made a cheap setup (ca. 200USD) to benchmark masks for pressure drop and filtration efficiency while worn on a (dummy) head. All components are off the shelve. I happily assist if anyone is interested in replicating this setup. I also can share the code to analyze the data, it's just very messy and nothing special, the whole 'algorithm' is disclosed in the text.
Your scatterplot was fascinating but I found it hard to tell which dot was which mask. Maybe put little numbers next to the dots? You can do this in Excel, where they are called data labels. Maybe use color to encode important parameters such as fabric type.
Thanks! I know... for now, check the interactive plot on github https://matts-ch.github.io/benchmask/either deselct some entries or use the hover over feature.I'm trying to improve it, but still struggling a lot with plotly...
