Just Another Cyberdeck
This cyberdeck is meant to be simple to print and easy to assemble.
The parts will all be printed on a Ender 3. Since the Ender 3 has a minimally sized build plate parts will be printed in multiple sections and glued together.
The cyberdeck itself should be fairly functional. It will have a Raspberry pi with 8GB running Kali linux so you can do your hacking penetration testing directly from the device.
