After some thought, I've decided to print the base and tower. I figure I can always go back to the orginal plan of constructing it out of wood if it doesn't work out. It will just take some time. PLA with a fill density of 5% seems to be strong enough. With a little filler and sanding it should look good. Nothing is glued yet.
