UV sensor test
A project log for wind weather station
This is a product match the anemometer to measure the wind speed, also provide other interfaces and sensor to measure tem, hum, and so on.
makerfabsMakerfabs 05/13/2021 at 08:390 Comments
I purchased one UV sensor grove in seeed, which is an expansion to measure the intensity of incident ultraviolet(UV) radiation. For creating the value which displays on the OLED of the weather station, I tried to connect the UV sensor grove to the expansion interface of the station. Following the wiki of the UV sensor grove, I have finished the programming. Now, show the result I tried.
