In order to give this project an additional advantage used when Sargassum is not being cleaned up, it is equipped with a roller coaster chair for tourist to enjoy the shore of the Caribbean which will widen the project scope.
A project log for Caribbeans Sargassum Problem 6.0
This project is about building a semi automation cleanup mechanism that can clean and collect the piled up Sargassum in shore land.
