PCB Manufacturing
A project log for RoDog
3D printed Quadruped Robot
wissam-tedrosWissam Tedros 08/26/2022 at 16:510 Comments
In this blog I will walk you through how you can order one of the Boards for yourself, and present you my experience with PCBWay, who decided to Sponsor my board, Big shoutout for them :)
PCBWay has a quick PCB order option where you can simply Upload the GRB.zip files, then the page will automatically load again with all the parameters needed to proceed with the order. Do not worry if the small GRBR viewer shows with some defects, you can have a proper view by visiting their online Gerber viewer.
Next the site will ask you to name the 4 layers of the board, Do as shown in the following picture
I benefitted from PCBWay's assembly service as there a Lot of Small SMD parts on my board, on both sides that I don't feel comfortable assembling by hand, so you can choose to do so by scrolling down and checking the "Assembly Service" section, you can either input all the parameters or, PCBWay will do that for you once you upload the BOM and xyz files.
After submitting all the files, you will have to wait 24hrs for engineering audit which of course, this board passes, Due to the current chip shortage, you might be contacted by the support team after the audit informing you that some parts are out of stock, PCBWay suggests for each missing part a replacement and inform you of the lead time (usually between 7 and 14 days), I tried to make this board with ICs that were in stock on Mouser, Digikey, and LCSC, but unfortunately there's no way to guarantee the availability of all the components.
Once happy with all the parts, you can then pay for the board manufacturing, assembly and parts costs, and choose your preferred shipping method, in no more than three weeks your assembled board will be at your doorstep.
I even had some wrong parts that I needed to replace after the confirmation of the quotation, by simply contacting the support team they accepted to replace the wrong part with no additional cost :)
Before shipping, PCBway sends you a Picture of your assembled board to confirm if everything is spot on, and sure enough it was, here are the pictures that were sent by their support after the assembly
Finally, here are some pictures of the board taken by me, when it was delivered:
I highly recommend PCBWay for any PCB manufacturing you need, especially if you would like to get one of this board, you can find the files in this blog under the "files section".
